Drag Racing Tech
Lowering springs in front effect 60'?
Old Jul 20, 2004 | 04:26 PM
BADFNZ's Avatar
Default Lowering springs in front effect 60'?
The front of my car sits about an 1" higher than the rear. I was thinking of either cutting some stock springs and putting them in front or just putting lowering springs in front. Would a stiffer rate spring in front effect 60' at all? I have stock springs in the back with the spring isolater removed and am just wanting to lower the front a bit.
Old Jul 20, 2004 | 04:57 PM
bad2000ss's Avatar
As I understand a stiffer spring in the front will allow better transfer of weight to the rear of the car, keeping the nose of the car from rebounding as quick as a stock spring. So yes a stiffer front spring will help with the 60' times.
Old Jul 20, 2004 | 11:58 PM
GueSS Who's Avatar
If the front was 1in lower then the rear it might help also. You want to pick up the weight to transfer it.
Old Jul 21, 2004 | 02:46 AM
BADFNZ's Avatar
I was expecting them to hurt if anything, not help. But I guess I learn something new everyday.
Old Jul 21, 2004 | 10:04 PM
SILVER BULLET's Avatar
When I had lowering springs my 60' were suffering because the nose was having trouble picking up and transfering weight because of the spring rate. I went to 12 way adjustable HALs and was able to adjust the ride height to where I wanted it.
Old Jul 22, 2004 | 02:14 AM
BADFNZ's Avatar
I think that'd probably be more due to the still rear springs rather than the fronts.
