drag racing helmet
I was thinking maybe one of these It says unisex helmet but is dot approved? According to my head circumference i need a large at 23inches. Maybe this one
Your call, but you spend as much as you think your head is worth
Having rode through more than 1 high speed (> 100 ) crash, i go higher not lower.
You can spend up to a $2000
My current helmet is a Bell M rated helmet, IIRC it was about 600 bucks.
They have expiration dates, current is a SA2020 cert I believe.
If your going fast enough to require a cage,, you should wear the right gear..
I've also worked a lot of track support pulling folks out of bent cars.
Youd be surprised how much of a beating a helmet takes..
