Drag Racing Tech
26 or 28” tire
Old Sep 14, 2022 | 09:02 PM
spina74's Avatar
Default 26 or 28” tire
I know this has been asked before but I’m not quite sure still. I’m running a 01 ws6 m6 that’s making 442 to the wheels with 3.90s. I’m currently trapping 118 in 4th with 275/40/17s. I’m switching to a 15” wheel. I’m still not sure whether I should get a 26 or 28” tire. Any input would be helpful.
Old Sep 14, 2022 | 09:43 PM
Bspeck82's Avatar
On motor stay with 26
Old Sep 14, 2022 | 09:48 PM
Tuskyz28's Avatar
Stay on 26" tires and make sure you ditch the front sway bar
Old Sep 15, 2022 | 03:59 AM
nj02z's Avatar
Ii run 3.90 gear ratio with a 27x11.5x15 QTP on two cars. If that's not an option go 28, It will be more forgiving than a 26.
Old Sep 15, 2022 | 07:25 AM
Shadow02SS's Avatar
I like the 27x11.50 with 4.10's with a six speed, that is what I run
Old Sep 15, 2022 | 10:27 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Slick or a radial?
Old Sep 22, 2022 | 10:50 PM
98RedCar's Avatar
28. Go big or go home. #1 rule of drag racing.
Old Sep 22, 2022 | 10:53 PM
98RedCar's Avatar
If you go 28" then make sure it's a radial slick. 28" bias ply slicks will rub on the big end (because they grow the faster they go). Been there done that.
Old Sep 24, 2022 | 05:59 PM
LS1Tech Co-Founder
I'd stay 26" if you are near full weight.
Old Sep 27, 2022 | 06:28 PM
Sprayed 99's Avatar
With your gearing and power level go with a 26x11.5 on a 15" rim.
Old Sep 29, 2022 | 06:44 AM
LS1_99TA's Avatar
My car is an A4, full weight and ~450 RWHP, 4.11 gear. With the M/T P275/60R15's (28.2" tall) tire, my top end RPM is only 6500, even though I have a loose (4500 stall) converter. I am going to try a 26" tire (like the Hoosier 26/10R-15 or 26 x 8.50R15) to get the trap RPM over 7000. I have good heads, a FAST 102 and 102 TB, so it likes to breathe at higher RPM.
What is your RPM @top end? If you're still making power over 7000, then the smaller tire should be quicker.
Also, FWIW, the stick shift NHRA Stock Eliminator guys I work with use a bias tire because they recover better than a radial if the tire starts spinning, Your mileage and track prep may vary.
Old Sep 29, 2022 | 08:34 AM
Shadow02SS's Avatar
What does your car ET and mph?
Old Sep 29, 2022 | 03:56 PM
LS1_99TA's Avatar
My car currently runs 11.20's @119 at an altitude track (1000' elevation, barometer usually 29.2")
Weight is 3500# w/driver, A/C, P/S all connected.
Old Oct 1, 2022 | 06:24 AM
Doug G's Avatar
Shorter tire may 60' better, but top end may suffer.
Catch 22
