Drag Racing Tech
Bump steer kit
Old Nov 22, 2022 | 11:13 AM
nickp's Avatar
Default Bump steer kit
On a 4th gen F body with tubular A arms and tubular K member, is a bump steer kit necessary even when still using all the factory steering rack, tie rods and spindles? Single adj Qa1's with 275# springs. Ride height is about the same as factory.
I have read you dont need to worry about it. And I have also read they need it even using the factory steering components. This is a street/strip car so I dont care about cornering. I'd just like to know how to check and or adjust the bump steer so its set up properly for drag racing.
Old Nov 22, 2022 | 01:48 PM
biketopia's Avatar
with the weight of the car on the ground, are the tie rods level, or at least close to level?
