Drag Racing Tech
What should I run?
Old Sep 18, 2002 | 07:57 PM
CorsicaLT1's Avatar
Default What should I run?
What do you think I should run from my stock times, compared to my current mods? Lets say 60-65 deg. weather.
1. LS1 edit tuning: Fans on earlier, slightly harder than stock shifts.
2. AutoTap: MAF-T w/good tune.
__________________
Homegrown Kentuckian
"Bone stock '01' WS.6, A-4"
Stock tires, full tank gas, no mods, no weight reduction.
60'- 2.089
1/8- 8.672@ 84.20
1/4- 13.35 @ 105.29
93F, 47Rel. Hum. & 29.36 Baro @ Cecil Co. Dragway, MD
Current Mods:
De-screened MAF, shimmed thermostat at 160 deg, B&M 24k trans cooler, insulated fuel lines, insulated IAT, Low-speed dual fan turn-on switch, tb bump stop to 4.6v, raised airbox, water wetter, valvecover breather, ls1 edit, autotap, tb coolant bypass, removed front swaybar, ported & polished MAF, MAF-T, raised coils 1/4", short belt & striped weight. No times yet.
Old Sep 19, 2002 | 02:14 PM
CorsicaLT1's Avatar
Default Re: What should I run?
Anyone?
Old Sep 19, 2002 | 04:06 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You went '1/4- 13.35 @ 105.29' without any of those mods?
In 60F weather I drove a 00 Formula to 12.85@110 with cutout, GSC's, lid, filter, !jack/spare and that's it. Also drove a 00TA to 13.03@109mph right after that.
I'll say 12.9-13.1 at sea level with like 0 DA.
Old Sep 19, 2002 | 07:02 PM
CorsicaLT1's Avatar
I'll be happy with a 13 flat. I would really like to break 12's with current mods, then go crazy with the parts. It was fairly hot when I ran it last. I believe my biggest help is actually going to be air quality. The first time I ran it, every run I made was faster & faster, so hopefully I get a descent amount of runs in.
