Drag Racing Tech
Manual brake conversion with skinnies
Old Oct 25, 2024 | 02:02 PM
fastlt1's Avatar
Default Manual brake conversion with skinnies
Would you swap the lines going front brakes to rear? Would that do the same as a proportion valve? Or be a better start?
Old Oct 26, 2024 | 10:31 AM
bbond105's Avatar
Yes, move the line for the rear brakes to the rear of the master cylinder. You can try it without a proportion valve, it should be close to the correct brake bias. If not, you can always go back and add an adjustable proportion valve.
