Drag Racing Tech
installing moroso line lock?any help!!
Old Oct 1, 2002 | 01:17 PM
9secpacecar's Avatar
Default installing moroso line lock?any help!!
does anyone have diagram of this install on 2001 ?tia.
Old Oct 1, 2002 | 01:38 PM
GeorgeC's Avatar
Default Re: installing moroso line lock?any help!!
All it does is go inline in the brake line that goes to the front brakes (which is the rear line on the master cylinder). I don't know if most folks put it before or after the ABS module, and I removed the ABS module at the same time that I installed my line-lock.
If you don't want to go through the hassle of bending tubing, flaring tubing, and trying to figure out where everything goes, Thunder Racing sells a complete kit that is available by itself or with a line lock.
Old Oct 2, 2002 | 12:23 AM
ForceFedPerformance's Avatar
The Quickest Way For Me To Help You Would Be To Show You One Installed. Go To www.forcefedperformance.com Click On Vehicle Profiles, Scroll Down To The Silver 02 Z28 Labeled Mike E. There Are Pictures You Can Click On That Will Show You A Close Up Of One Installed. If You Want Call Me At 1-530-755-0337 & I Will Help Answer Any Questions You Might Still Have.
Old Oct 6, 2002 | 11:37 AM
thanks that helps! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
