Drag Racing Tech
Not so happy with results
Old Aug 5, 2004 | 05:33 PM
nikon1999's Avatar
Default Not so happy with results
I installed 3.73's in my car from 2.73's, ran ET Streets on the car instead of the stock GSC's, and was expecting to hitt 12's. My old best before gears/tires was a 13.28@105.9 on a 2.1 60'. With gears/tires i made 3 passes.
13.8@105.6
13.39@105.7
13.29@105.8
Needless to say im a little unhappy with the results
Old Aug 5, 2004 | 05:39 PM
TexMax's Avatar
What were your reaction times before and after? My best guess w/o seeing a timeslip would be that your takeoffs were worse after the mods.
Old Aug 5, 2004 | 05:57 PM
artic-z28's Avatar
converter + tune = 12.5's probly better
Old Aug 5, 2004 | 06:06 PM
BlueSix's Avatar
stock converter + ET streets = poor results.
Old Aug 5, 2004 | 09:07 PM
nikon1999's Avatar
one problem is i couldnt stall the car past 1500, the brakes wouldnt hold. The car is tuned, but it was short shifting first a little bit. Maybe need to adjust the shift points a bit. A converter seems to be a must now.. the car has it up high but needs more help getting there. Get its big butt movin
Old Aug 5, 2004 | 09:27 PM
SilverGhost's Avatar
Motorboater
what is with people not posting any damned needed info around here lately when asking a question
hard to comment on the before/after comparison without knowing the sixty foot on those et street passes...
Old Aug 5, 2004 | 09:30 PM
Motorboater
this is the second thread i've looked at in 2 seconds where you've said this and it is not correct. are you confusing r/t with sixty foot?
Old Aug 5, 2004 | 11:10 PM
BlueSix's Avatar
I was wondering that same thing.
Old Aug 6, 2004 | 05:45 AM
nikon1999's Avatar
sixtys on street tires ranged from 2.11-2.18
sixtys on et streets ranged from 2.03-2.12
Old Aug 7, 2004 | 04:51 PM
artic-z28's Avatar
i pulled 1.8 60ft's on sumos street tires
Old Aug 7, 2004 | 05:05 PM
Quickshotkimber's Avatar
What size were the ET streets? You are giving back gear if they are taller than your stockers.
How wide are they? I think they are costing you more up top than they are helping you down low. A nitto or comparible DR is all that you need at your power level. Anything more is overkill and will slow you down.
Just my 2cents
Old Aug 7, 2004 | 06:45 PM
thechef's Avatar
Moderator
what psi are you running the et streets at???
Old Aug 9, 2004 | 12:34 PM
Noyzee's Avatar
8 second mod
the weather was about 80* with very high humidity! The car short shifted with the et streets for some reason, and the car just wouldnt stall. we get the brake thing fixed and a stall the thing will fly.
id say converter and a nice set of drag radials and 12.5's for sure!!!
Old Aug 11, 2004 | 08:26 PM
LittleBoyBlu99's Avatar
Sounds like your shift points need to be redone. Find someshop with LS1 edit or Hp tuning and this should make a big difference.
