Drag Racing Tech
K-members, which is lighter?
Old Nov 26, 2002 | 05:07 AM
badass 2002 z28's Avatar
Default K-members, which is lighter?
PA mild steel or BMR mild steel?
Old Nov 26, 2002 | 08:54 AM
Paul F's Avatar
Default Re: K-members, which is lighter?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by badass 2002 z28:
<strong>PA mild steel or BMR mild steel?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The BMR is lighter because of thier motor mounts.
Paul
<small>[ November 26, 2002, 08:54 AM: Message edited by: Paul @ Thunder ]</small>
Old Nov 26, 2002 | 09:51 AM
CHRISPY's Avatar
How much lighter? Anyone know exactly what BMR's gear weighs?
thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 26, 2002 | 09:55 AM
Mike Hoffpauir's Avatar
mild steel BMR is 31 pounds lighter than stock kmember.
I'd be curious to see how much a cromoly PA k member would weigh when used with Madman motormounts. This might be even lighter.
Old Nov 26, 2002 | 10:14 AM
Smoke_ur_5.0's Avatar
After checking wieghts with the different kmembers..the BMR comes in the lightest..like mentioned earlier because of the built in motor mounts.
Old Nov 26, 2002 | 10:47 AM
2000SILVERTA's Avatar
How hard is a k member to put in? Time? Can it be done in my garage? Is a lift a must?
Sorry to Hijack the thread, but I think we got the BMR is lighter.
Thanks.
Old Nov 27, 2002 | 02:27 PM
MADSCI's Avatar
9-Second Club
Hey guy`s just to let you know our chrome moly tube k-frame and a-arms weigh in at 27lbs!! which if I`am not wrong that`s about 40lbs dropped! if your interested check out our specials! https://ls1tech.com/ubb/ultimatebb.p...;f=10;t=001292 <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
Old Nov 27, 2002 | 09:43 PM
thanks for the replies <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Nov 28, 2002 | 06:36 PM
red ws6 99's Avatar
2000SILVERTA, yes you can do it in the garage. Pull off the shocks/uprights or support them with jack stands. Support the engine with jack stands. Remove the 8 motor mount bolts, rack and pinion, brake lines, and 6 retaining bolts. Put new one in put everything back in. You will have to fabricate something to hold line to the k-member at least were it goes from tube to hose.
Gary
Old Nov 28, 2002 | 06:58 PM
Air21's Avatar
barry does your k member use stock A arms?
