Drag Racing Tech
guys with air bags come inside....
Old Dec 10, 2002 | 09:45 PM
TApimp's Avatar
Default guys with air bags come inside....
what kinda psi are yall running iin them at the track? or on the street.
Old Dec 11, 2002 | 06:38 AM
Jon Green's Avatar
Default Re: guys with air bags come inside....
I run 2 air bags right I run 15psi and on the left I run 5psi but most people run 1
Old Dec 11, 2002 | 09:24 AM
1madss's Avatar
I run 1 bag in the right side at 20lbs. It worked great for getting my launch straight again.
Old Dec 11, 2002 | 01:16 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
I run one RR air bag at 23 psi. Your psi will vry depending on your HP/TQ at the launch. It's best to have someone video tape you or watch the car from behind when you launch at the track , then just keep bumping the psi up until the car launches straight and level. FWIW- I used to run 15 psi before the heads and cam. I hope this helps. Take care.
James
Old Dec 11, 2002 | 02:40 PM
Larry's Avatar
I run 12 psi and only a passenger side air bag along with my factor rear anti-sway bar.
I run 1.58, 1.57 60' times and hold traction every time with 26 x 11.5 x 16 ET Streets at 25 psi on factory wheels.
Old Dec 11, 2002 | 04:11 PM
Moose's Avatar
I run 28- 30 lbs in my RR air bag.. car really squats when launching. I let the air out on the street for a nice smooth ride..
Old Dec 11, 2002 | 06:56 PM
WJ SOM SS's Avatar
I run 15-20 psi. Right side only. '02 A4 SS car. It works good. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> WJ.
