Drag radial question
They should be fine worn like that. When you replace them, either get the new M/T ET Street Radials, or M&H now makes a 275/55-16 DR! It is 28" tall. Finally, another 16" drag radial size!
Al
I run consistent 11's on these.Exact times depending on the amount of N2O I am spraying.
I have over 1,000miles on them and around 20 passes.
I run at 21psi at the track and no more than a 5 second burnout at 5,000rpm in first.You do NOT need to burn these tires down to get them sticky. Just clean them up and warm them a bit.
On the street I keep them from 27-30psi.
I still have a decent amount of tread showing.
