Drag Racing Tech
Weight Reduction question
Old Jan 12, 2003 | 01:52 AM
Slick9.5's Avatar
Default Weight Reduction question
what suspension components can i replace with lighter after market parts. also is there anything else under the car that i can remove and/or replace?
Old Jan 12, 2003 | 01:58 AM
sited12's Avatar
Default Re: Weight Reduction question
Front sway bar should be the first thing. Car will transfer weight so much better.
Old Jan 12, 2003 | 08:22 AM
Colonel's Avatar
Panhard rod, LCA arms, K-member, A-arms, upper control arms, TQ arm
Do a search for my weight reduction thread. It has ALOT of good ideas.
Old Jan 12, 2003 | 02:39 PM
Slick9.5's Avatar
allright thanks colonel, Ii have seen your posts about weight reduction, I was also wondering how much weight do you think I can remove by replacing all of those suspension parts?
Old Jan 12, 2003 | 04:54 PM
quickWS6's Avatar
Depends on if you just replace stuff. By only replacing stuff (not removing anything that you don't replace) you're only looking at about 40-45 pounds.
