14 sec Z28 WTF HELP
Sounds like you are dealing with some horrid weather...high humidty and heat will slow a car down several tenths and mph..what is your mph by the way?
do you have access to Autotap? I always suggest logging a few runs so you can check for problems like KR, big misfires, take a look at the shift extensions and make sure the car is shifting properly, etc...its hard to guess if there is a problem without some data to look at..
how old are you plugs and wires? how old is your fuel filter?
I'd start taking out variables like that by swapping in some NGK's and some good wires and putting in a new fuel filter, etc...when hunting for a possible problem I always knock out the simple variables/elimate the possbilities.
