Bolt on performance mods
Cat back
Headers
Y pipe
Remove front sway
Slicks and skinnies
Air box lid
LS6 manifold
AC short belt
Underdrive pullies
A arms and K member
Hal shocks
160 degree thermostat
torque converter or clutch
Rearend gears
manual steering rack
Air filter
MAF
Relocate battery to trunk
I know i am missing a ton more so anyone please help me.
<small>[ February 12, 2003, 12:31 AM: Message edited by: sited12 ]</small>
-ram-air induction of some type (recommended if not WS6), i.e. Fast Toys Ram Air
-high-flow bellows
-lots of suspension stuff
-merge collectors
-true dual exhaust conversion
-hacked-up airbox for more airflow
-TB coolant bypass
-EGR mod
-electric water pump
-tuning via one of the 8 million methods we have now
-lighter driveshaft (careful not to sacrifice strength)
I'm sure I've missed some as well. But, there's a few more for ya. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Also, FWIW, the A/C is driven by a separate belt than the other accessories. The "short belt" most of us refer to bypasses the power steering. You can just remove the A/C belt completely (if not the whole A/C system <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ).
<strong> Base on review of your list you are well on the right track. I would suggest Hal drag springs and a port and polished throttle body. I would work on the suspension first and then move to the Bolt-ons on the motor. Also, a good tune can give you additional performance. Good luck in your quest. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I havent done them all yet but i am planning on them. I want to get my whole car set up and run 11.3 if not lower as a bolton car and then the only thing left would be to drop my motor in that i am building. Thinking of building something like BeaSSt's 436 if i can sneak a small amount of information from them. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I already mentioned the electric water pump, that's why I didn't guess you were referring to it.
<strong> I want to get my whole car set up and run 11.3 if not lower as a bolton car and then the only thing left would be to drop my motor in that i am building. Thinking of building something like BeaSSt's 436 if i can sneak a small amount of information from them. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">an 11.3 as a bolt-on car in Chicago?? WOW! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I would definitely be impressed with that. Best of luck to you. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
later,
Steve
I was able too dead hook w/a street tire and 3.23s before the converter.
MODS:
TP4400
Lid
Hooker LT headers
12" extensions off the headers into Flowmaster 1-Chambers dumped under the front seats
3.23 gearing
skinnies
26x10.5x16 ET Streets on 16x8 Weld Draglite XP's
shift point adjustments/TM removal/rev limiter adjustments
tubular LCA's
That's it, oh yeah, weight reduction <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> My car weighs right in at about 3200 w/ me in it. I weight 165lbs. I have a lot of stuff out of the car, but there was so much more i could do too. LS6 intake, ASP pulley, MAF ends, ported TB, was going to do 4.10's/28" tire, tubular k-member/a-arms, suspension stuff, etc...(and the more I look at the list that you guys have put together, i realize how much more stuff there was i could have done... DAMN i wish i was still building that car)
You can get there. Just need to follow what the others have done and go from there. US41 would probably be a better track to hit your goals at, but you can always try everywhere else. I was well on my way before my shortblock blew(rod bolt). Good luck!
Chris
PS- my weight reduction was, well, not typical, but definitely NOT to the Extreme. here's my little website to give you a little more reference on what was taken out.
My Webpage
<small>[ February 17, 2003, 07:30 PM: Message edited by: z28kid98 ]</small>
Chris
fwiw, my car went 13.2 with 2.73s and a lid.
