Drag Racing Tech
LT1 Throttle Stop???
Old Feb 27, 2003 | 02:10 AM
BigKevC5's Avatar
Default LT1 Throttle Stop???
Anyone know of a company that sells a throttle stop for the LT1?
I wanna run Super e/t this year.... But without one... It would be a waste of time.
Old Feb 27, 2003 | 09:45 AM
KTamez's Avatar
Default Re: LT1 Throttle Stop???
I've never seen anyone make something specific however, I'm sure you could make one of Dedenbears linkage style stops work.
http://www.dedenbear.com/TXTtsBase.htm#TS10
Good luck!
Old Feb 27, 2003 | 11:44 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Iam sure Madman can help you out with this one. Give him a call at 281-444-8833. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Coach
Old Feb 28, 2003 | 07:06 AM
GeorgeC's Avatar
If you have some ingenuity and a little bit of fabrication skill, you can make one of the linkage style stops work. I am going to adapt one to my car sometime, but I just keep finding other things that need to be done first...
Depending on how much under the class index you're running, you may want to just consider a mechanical stop/throttle limiter. Two years ago I bracket raced all season long in the "Sportsman" class which has an ET break of 12.00. I used a mechanical stop on my throttle body to slow my car down from ~11.2's down to 12.1's. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Feb 28, 2003 | 10:19 AM
cenman's Avatar
george, can you give more detail on your mechanical stop? was it just something blocking how much the tb opened on wot? any pics? thanks.
Old Feb 28, 2003 | 10:35 AM
GeorgeC's Avatar
No pics, but it was a very simple thing...
I have a hole drilled and tapped in the "bump-stop" section of the throttle body. I run a 3/16" bolt in from the backside and secure it with a jam nut on the front side. Depending on how far the bolt is threaded in, I can limit the throttle travel anywhere from a little to a lot. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 28, 2003 | 10:45 AM
CHRISPY's Avatar
Would this cause probs for cars running closed loop tuning? is: trying to maintain a AF of ~14:1 and T-blade angles under 80%?
Chris
Old Feb 28, 2003 | 06:54 PM
GeorgeC's Avatar
Back in the "old days" my car was still using closed loop. I never had any issues.
Think about it for a second... Can't you drive your car around @ 1/2 throttle without anything bad happening? The only issue may be tranny line pressure, but I had a TH350 at the time, so it wasn't an issue. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 1, 2003 | 12:48 AM
RyanJ's Avatar
SSU Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong> Would this cause probs for cars running closed loop tuning? is: trying to maintain a AF of ~14:1 and T-blade angles under 80%?
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">sounds reasonable, but couldnt you just program (if available) the PCM to see closed loop at whatever percentage?
Old Mar 1, 2003 | 12:54 AM
CHRISPY's Avatar
not sure, possibly...
Cheers,
Chris
