Disappointing 60'/ET - advice?
Cooked the tires pretty well, and they hooked on the first three passes, but all the 60's were in the 1.93 - 1.98 range. ET same as w/street tires - 12.9XX. I had the pressures at 16 lbs, and launched at idle once, 1000 rpm twice. Matted the throttle off the line, and like I said, it dead hooked - zero spin. Loaded it up to 1400 for the fourth pass and it wheel hopped to a 2.04.
Car has lid/cutout and not much else. Am I being unrealistic in my expectations, or is this just about all it should be capable of without a verter?
TIA for any experience you can give this racing rookie!
<small>[ March 02, 2003, 09:21 AM: Message edited by: KatmanSS ]</small>
<small>[ March 02, 2003, 09:59 AM: Message edited by: YT FIRE ]</small>
James
Although a Torque Converter will help too, now that you have Nittos & can hook that kind of power up. If you have the money, I'd do both! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
you need nittos because like the above said et streets are actaully gonna slow you down. I took 16inch nittos to a 1.58 60 and 11.95 stock internals on a vig3600 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
so you wont need et streets unless you start doing heads/cam work <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
right now your not gonna see much below a 12.9 untill you get stalled <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
