Still running 13.5
All the other cars there trapping 106 and 107 were 12.8 ro 12.5 cars. I just need to pray my 10 bolt holds.
Oh I forgot to mention. the difference between my 13.7 and 13.5 was :
- put my stock wheeles back on
- installed Jantzer TB
- went from 3.73 to 4.10s
But like i said, my real question is just that at 106 mph should I be capable of high 12's?
Lemme konw what you think.
Thanks
Im racing at 75&80 in Maryland wich is konw to be a bad track for ETs because of its slight grade, but still!
I may go get a dyno test to see what im putting out. But my MPH is still decent. Its right there with all the other 12.5 to 12.8 cars that I saw there today.
DOnno.
I ran a 13.5 @ 104mph with a 2.1 60' with 4.10's and DR's ( Spun the tires of the line on that run)
I bet 2nd gear is killing you mostly. With street tires, I couldn't get 2nd gear to hook up. Best time I had on street tires was 14.0 @ 104mph with a 2.1 60'. The drag radials dropped a half of a second of my ET's because I was able to use 2nd gear without spinning the tires all the way through it.
The pass after that I got it down to a 1.9 60' but I missed a shift
That would have been a very low 13 or possibly a 12 second pass.
I was running my stock 17" 10 spoke SS wheels with 275/40/17 BFG Comp T/A's @ 22psi. Still not enough traction though. I think Im going to have to get some Drag Radials and cross my fingers for the rear to hold.
