Info on Wheel weights inside...
Stock Z-28 Wheels (the funky twin 5 spoke not the true 5 spoke) w/ Overly bald, cord showing Nitto 245/50/16's =39.4lbs
Stock Z-28 Wheels w/ factory Good-for-a-Year GSAs with half life (fronts) = 38.8lbs
ProStar 26x11.5x15 ET Streets screwed = 36lbs
proStar 26x7x15 (a little wide I know)w/7/16 spacers for caliper clearance = 29.9lbs.
Basically saved 20lbs on the front and very little on the rear, but the added grip is more than worth it.
Question for those grinders out there, how much can I safely remove from the outside edges of the front calipers and brackets? I would like to use a little smaller spacer, or none at all. I would be looking at possibly 1/4inch. Is this safe?
TIA. Charlie.
Just changed the rear diff fluid and installed the TA Rear cover w/ stud preloaders and a cheesy jegs el cheapo DS loop (need a little bending to get it off the torque arm). Two more days and its track time again.
<strong> man thats a little lite for a stock rim.my 98 chrome 16in 5-stars with 245/50 gsc-s weigh 44lbs ea.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Keep in mind that he had GSAs which are normally 235x55 as opposed to GSCs/RSAs which are 245x50, I doubt it's too much of a difference but could be.
