Drag Racing Tech
DRs on or off
Old Mar 20, 2003 | 03:29 PM
WHITE00SS's Avatar
Default DRs on or off
i put the drag radials on the ss and and was hoping for better times but got worse i went from a 13.0 @106 on stock f1s to a 13.4@102 on drags it bogs on take off and best 60 i could pull was a 2.1 and with my f1s i pulled a 1.7 what do yall think should i go back to the f1s. thanks
Old Mar 20, 2003 | 03:58 PM
RedlineLS1's Avatar
Default Re: DRs on or off
Go with what ever makes you get better times <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 20, 2003 | 07:47 PM
LS1LT1's Avatar
Unless there is something now mechanically wrong with your car that wasn't wrong before, I believe that when driven properly, it is nearly impossible to run a slower time on DRs (BFGs or Nittos) as opposed to Eagle F1s (a very hard compound tire) unless it's on the coldest of surfaces in very cold air. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Try it again, you WILL go faster.
Old Mar 20, 2003 | 08:06 PM
XFiveLiter's Avatar
Stock converter? I think that a little bit of spin is better than a dead hook w/the stock converter.
Old Mar 21, 2003 | 09:34 AM
FastAl's Avatar
If you got Nittos, you have to do a nice long smokey burnout otherwise they will hook no better and sometimes worse then street tires. BFG's don't need anything like the Nitto burnout though.
When I was running Nitto's, I would adjust the rearview mirrors to see the tires. Start my burnout when I saw smoke count to 15 then roll out of the burnout I still couldn't do better then a 1.9 60" with my M6 though.
Old Mar 21, 2003 | 10:56 AM
Lar's SS's Avatar
Did you change the way you launch? The key thing is you said you bog now. So, leave a little harder and find the new magic RPM for your car. Adjust air pressure, consider track conditions and temp. A good conditioning burn out is needed too for brand new tires. You gotta keep working it out.
Old Mar 23, 2003 | 03:58 PM
ULTIMATEORANGESS's Avatar
your car should run better with DRs with nothing else done to it.it was one of my first mods.work on your launch and youll see positive results. <img border="0" alt="[gruffy cottonball]" title="" src="graemlins/gr_gruffy.gif" />
Old Mar 23, 2003 | 11:54 PM
WS6MB's Avatar
I am in the same position. With F1's i went 12.8 at 112. Now with 315DR's i am consistant at 13.0x at 109. with 2.1 60's. I am affraid to launch any harder with the stock rear. So spining a little with the f1's is faster for me. Go with what is faster for you.
