Drag Racing Tech
struggling at night!
Old Sep 12, 2004 | 01:37 AM
TraajicLS1's Avatar
Default struggling at night!
I have a A4 99 Camaro SS lid/cutout/ suspension and ran at Houston Raceway Park for the last two weeks
I have yet to run a decent time for my car at night, (my best being a 13.55 @ 102 in the dusk hours)
i can run the same identical 60 foots and be 3-4 tenths off ..
is this a engine issue or a tranny issue?
RT ... .196
60' ... 2.157
330 ... 5.895
1/8 ... 8.931
mph ... 82.06
3000 ... 11.546
1/4 ... 13.773
mph ... 101.11
RT ... .242
60' ... 2.145
330 ... 5.982
1/8 ... 9.091
mph ... 80.31
3000 ... 11.749
1/4 ... 14.011
mph ... 99.51
maybe its time to start working on my mustang project
Old Sep 12, 2004 | 04:09 AM
White98Z's Avatar
Your best ever is 102 and you did 101 you should be makeing the power. Get a converter and some good tires and it should make all the dif. drop your 60 ft. And it will be all better.
Old Sep 12, 2004 | 01:02 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Tires my friend. You need some tires.
Coach
Old Sep 12, 2004 | 01:53 PM
Stu'sWS6's Avatar
I agree with the Coach-you need some traction. Is this a 2.73 geared car? The mph looks a little low; a good torque converter and gears (3.23 or 3.42) would help considerably. Look into getting some drag radials, I cut consistant low 1.6 60fts on 275/40/17 nittos in a bolt on 99 A4 WS6
Old Sep 12, 2004 | 04:03 PM
TraajicLS1's Avatar
i have Goodyear Eagle GS-D3s and they sometimes slip up (not even a half a rotation of the tire) leaving the line but otherwise hook well before the 60' mark
i have a 3.23 gear in the back
those times i listed above ... i ran a better 60' but lost almost 3 tenths down the track .... so that has me suspecting the tranny or engine....
my best 60' to date is a 2.063
Old Sep 12, 2004 | 05:37 PM
SilverGhost's Avatar
Motorboater
well if you always run a bit slower at nite it could be weathe related.
humidity tends to go up in the evening..it goes up alot around here anyway.
Old Sep 12, 2004 | 06:06 PM
TraajicLS1's Avatar
i looked at the weather reports for last friday .... humidity stayed the same and the temp dropped 2 degrees ...
im curious to see if its the tranny ....ide like to look at temps sometime ...
Old Sep 15, 2004 | 09:32 AM
ChevyGoldfinger's Avatar
How many miles on the tranny? How does the fluid look? Nice clear red, and how does it smell? You can smell burnt clutch packs. You definitely need some good Drag Radials or ET Streets if you ever plan to get a decent 60' time and remove your front sway bar for weight transfer. If your tranny needs attention, you can get it freshened up w/a shift kit and get a nice stall converter at the same time. (I have a 99 Z/28 and was at your level about 3 years ago)
I did the ET street thing, and got a Vig 3200 stall and Jet Hot Long tube headers. Made a huge difference, only wish I would have tracked down an LS6 intake too. That would help your top end power along with a ported TB.
You don't have to do everything at once, but everyone starts out where you are. Better make sure about the tranny first before anything else. Good luck.
Old Sep 15, 2004 | 03:54 PM
TraajicLS1's Avatar
the fluid is a nice red with no smell to it .. 42000 miles on the tranny
i bought at a 160* thermostat and im going to track down a Tranny Cooler tomorrow ...
at the line the tires sometimes chirp but otherwise they hook ... i just lose alot of time at the shifts
ill test out the tranny cooler.. and hope the problem is being cause by high tranny temps
Old Sep 25, 2004 | 10:53 AM
TraajicLS1's Avatar
problem fixed ..... ran consistant all night long
ran a good 15 passes tonight
best being
R/T ... .092
60' ... 2.032
330 ... 5.715
1/8 ... 8.713
MPH ... 82.91
1000 ... 11.306
1/4 ... 13.515
MPH ... 101.89
my best individual times of the night
R/T ... .004
60' ... 2.018
330 ... 5.698
1/8 ... 8.695
MPH ... 82.77
1000 ... 11.306
1/4 ... 13.515
MPH ... 101.89
Old Sep 25, 2004 | 12:59 PM
best being
R/T ... .092
60' ... 2.032
330 ... 5.715
1/8 ... 8.713
MPH ... 82.91
1000 ... 11.306
1/4 ... 13.515
MPH ... 101.89
R/T ... .004
60' ... 2.018
330 ... 5.698
1/8 ... 8.695
MPH ... 82.77
1000 ... 11.306
1/4 ... 13.515
MPH ... 101.89
Those numbers sound about right for a bone stock 99 at your elevation. If you were up here at 2250 ft. elevation, that would add a half second to your times and you would be struggling to break into the 13's!!
It's all relative, now you will find yourself wanting to go quicker and looking for your next mod. Choose your mods carefully. There are some that do next to nothing. I would suggest your next mod be a cutout, easy 15 RWHP gain. The electronically controlled ones are really nice if you can afford an extra hondo plus installation. I personally have tried both the QTP & the McCord Power Plate and find the McCord far superior in quality, plus it's cheaper and the customer service is great. The cutout alone will probably give you a couple of tenths or so, and then if you can pick up an extra set of rims (check the for sale sections) for cheap, and put a pair of E.T. Streets or Hoosier QTPs on them for the track, they will allow you to leave harder and not spin. Of course it never ends. . . The quicker you go, the quicker you want to go. Next big gain would be about a 3200 stall converter and trans cooler. This would take advantage of your sticky tires and drop your 60 foot times down to around 1.8 or a high 1.7x, which will be a very nice gain in E.T. (probably another 3 tenths or more)
Then long tube headers. . . and on and on. . . only you know when to stop the mods.
You may not want to do any of the major bolt-on mods if you use the car as your only source of transportation. The cutout is still a slam dunk for you even if it is your only car. You'll never find a cheaper 15 RWHP.
Good luck, and above all HAVE FUN
Old Sep 25, 2004 | 02:39 PM
DietCoke's Avatar
There ya go, sell him something he already has
Old Sep 25, 2004 | 02:53 PM
LOL Guess I should learn to read.
Well, scratch the cutout, since you already have one, but I stand by my other suggestions.
Old Sep 25, 2004 | 03:30 PM
TraajicLS1's Avatar
the car weighs a good a 3592 with me in it ...
i may have a tranny mount thats shot..... im getting all sorts of clunks when i hit bumps or when it downshifts ..
i ran a best of 13.86 at Nebraska (whatever their elevation is)
i launched at 1200-1400 rpms and hooked on my Eagle F1 GS-D3s so traction isnt a issue
i plan on getting my exhaust finished up ... (Kooks Headers & ypipe) as well as a 3200-3600 Converter ... 3.73 gears and some Drag Radials then......
im just pleased my times are now consistant
thanks for all the help & suggestions!!
Old Sep 25, 2004 | 03:49 PM
UB welcome!
Sounds like you're on the right track, when you get the converter installed, you will want to have the trans shop take a look at the issues and possibly do a rebuild before you completely destroy it. A 4L60E can be built to withstand a lot of HP if the right parts are installed correctly.
You might want to keep an eye out for a used LS6 intake on the for sale section, that's a real good mod and worth a good ten RWHP or more. Especially at the big end. Good luck!!
