Slow It Down
I will be 11.7-11.8 if I run full out, and am not allowed to run under 12.0.
Thanks for any suggestions, and please don't tell me to put in a roll bar & run it full out.
Kyle
To my knowledge, Englishtown is NOT adopting the Pure Stock rule in elimination races.
I participate in the Corvette Challenge, Gamblers, and other events they hold.
Just wondering if there was an alternative to weights.
Short shifting it sounds OK, but I was wondering if I got the Diablo Predator, would it save my current LS-1 Edit tuned program?
If it did, then I could just load up a stock program, less torque management & abuse mode, and that timing & other stock stuff might be the .2 to .3
I need in cooler weather..
Just drill and tap a hole in the throttle body (on the pad right behind the throttle arm), and thread in a bolt (3/16" is what I used, IIRC) and a jam nut to keep it in place. You can adjust the amount of "stop" to dial the car in right where you want it.
