Drag suspension setup Need your help
I need to get my sixty foots in the 1.4 range consistently.
What do you guys recommend for a drag racing suspension setup that gets driven on the street alot?
Here is my current setup:
28x9 inch slicks. 12.5 pounds air cold
Stock shocks and springs (front and rear)
Stock PHR
Stock Rear swaybar
Hotchkiss (old as the hills) LCAs
BMR Extreme torque arm
!front swaybar
I have run a best sixty of 1.52 so far with that setup at 3620 pounds. (The 11.10@125.05 pass was on a 1.54 sixty)
Right rear airbag is going in this week but I am thinking forward to the end of this season and next season.
I have looked at the Spohn drag swaybar which looks like a decent alternative to the solid bars but will an aftermarket bar be necessary with the airbag setup? I am on a budget and I drive my car frequently on the street so that needs to be taken into consideration. (I drive it 4-5 times a week)
How about Hal shocks and springs?
Is an aftermarket PHR really necessary for drag racing?
Thanks guys, greatly appreciated, I want a 10.90 before the snow flies.
I am going to compete in the OSCA Modified Street 10.90 class in the spring
I'll racing against the trailer cars with my emissions legal Formula so I'll need all the suspension help I can get! LOL!
def need to do front and back shocks and front springs. I would go with hal "R" series personally. I need to switch to these up front,too, i'm bounching way too much when i land the front end with regualar hals.
You know my opinion on doing a rear drag bar, its the way to go, period. BUT since you are on a budget and street drive a lot, maybe just see how the air bag does for the car first and go from there.
A decent adjustable panhard really isn't gonna do things for you for drag racing...I have one pretty much just so I can make sure my rearend is centered and because I don't tend to trust stock suspension pieces on my car, period.
I would put the R series shocks and springs at the very top of your list for sure.
I have thought about the BMR Kmember with mounts but no budget for it
My wife is leaving her consulting job in 3 days so the money tree is drying up fast!
Would you leave the stock springs in the back and just do rear shocks?
i run stock rear springs, i would def suggest that for you,too.
if you want to just change the rear shocks only you can spend next to nothing on a set of comp engineering 3 ways and stick em on 50/50 setting. they just aren't that hot cuz they only have 3 settings and you have to pull them out of the car to adjust them(no dial).
i would just go all four shocks r series and the hal front springs, that would give you a big advantage over your current setup imo.
Your car and your life, but in my humble opinion, the weight reduction isn't worth a cracked/snapped K-member which could lead to more trouble than you ever bargained for. Those tubular pieces were never intended for street use like you say you are doing "alot". Just a word to the wise.
i drive mine everywhere and anywhere when i have it out. i've had the k member for 2 years with no problems
I literally just cruise around on the street. No fast driving here. I go 75-80mph on the interstate to the track but otherwise I just putt around
