Explain to me how this works.
On a totally stock engine - 100 shot (last year) - M6 (at that time). My SS did 1.5's and 11.38 at 124 in the 1/4. Suspension was better than average. Track prep was only average. This year is totally different with an A3 so I will not go there.
Spinning?? .. If you are getting the weight transfer correctly - just on the engine you should be in the 1.5... On 100 shot at least 1.4. But to get these you need a very good suspension set up, adjusted correct and a damn good set of tires. More power you make the harder it is to put it all down to the pavement.
To many variables just to say one thing is different. And yes, by jetting up one set of fuel jets will slow it down. Again how much?? Maybe - big maybe - .1.
Not sure that this helps. But look at your suspension and tires. Are they cutting the grade?
David
if so, there is the reason you only gained two tenths.
remember for every tenth in the sixty foot you will gain roughly 1.5-2 tenths in the quarter..well you did the same sixty foot and then if you sprayed 2nd gear out its logical you'd only grab up 2 tenths with a 100 shot. the 7 mph seems on par as well for that scenario..
