Drag Racing Tech
Neutral safety switch
Old Oct 6, 2004 | 11:57 PM
sited12's Avatar
Default Neutral safety switch
Figure i would get a better response in here, since im sure alot of you guys have done the 4l60E to TH400 swap.
I bumped the wire off that bypasses the neutral safety switch in my car and i cant figure out how to put it back now. I tried every single combination you can do and the car still wont start. I changed nothing other than that. Could it be a bad wire now too that connects the two?
Old Oct 7, 2004 | 12:06 AM
Magnus's Avatar
LS1TECH Sponsor
There is a big purple and brown wire that go to the switch I believe.
If you just tie them together the car should start.
The other wires are for pcm info i think and rear hatch safety.
