M6 Dr launch question?
. I also have a cam and the usual bolt ons. So my question is which is the best way to launch a dr car i guess. I took it to the track and launching it at 3500 to 4000 produced the best runs. This is with the lt's,4.10's,dr's, and the control arms which produced a disapointing 13.2 at 110. With a 2.0 sixtyft. I had to do a second gear burnout for a while to get them to hook. Now im going to the track with the cam and a good tune. Should i not burn out so much and launch lower to let the tires spin just a bit or what. Any input would be appreciated. Im sort of new to drag racing a m6 car. Had an auto before in a 68 Dodge Dart. Thanks! I put my Nitto DR tire pressure down to 14 to 15 PSI COLD, do a 8-10 sec 2nd gear Burn out and then let off the brake and keep them spinning till it starts to hook a little. Then I roll up and stage bring the RPMs up to 3000-3500RPM (no 2 step so it is hard to keep it in one place!!) do what I call a controled dump, basically not just drop it totaly, more like a fast release and have managed low 1.8 60fts. But after a season of that I have just broke my 10Bolt finally
. But it will be way more fun with the 9" and a steel DS, and launching at 5500RPM
.Dan
Soon after getting the car in my sig, my %$#*&^@ Opti Spark went out and my low end torq went with it so I have only had a few months to play around with the drag racing.
But, that's the basics? Hold the gas down a bit and bring the rev up then dump the clutch?
EDIT: Won't this hurt the transmission? In an automatic do you keep it in neutral and bring the revs up, then down shift as you launch? Won't that kill a tranny?!
Dan
