Help in the plates plz
1) MADMAN motorplates and travel limiter without midplate.
2) APE midplate or motorplates without travel limiter.
Which one is better in your opinion plz
Thanks
Adnan
Unless you run a solid tranny mount, you need limiters. The front plate will flex. A solid tranny mount does nasty things to the tailshaft housing.
How thick is the midplate? You need to consider clutch/converter spacing, length of dowel pins in the block, etc, etc when you go w/ a midplate.
