Drag Racing Tech
How-To: Removing Door Bars
Old Jan 4, 2005 | 09:26 PM
critter's Avatar
Originally Posted by GIZMO
Start to finish it takes me about thirty minutes to do one door.
LOL!!! I should have hired you! An hour's work can't cost that much!
Seriously, the second door went better, having done the first. It took a few minutes to get the door panel off this time, 25 minutes to cut the bar, 25 minutes to chop the rear part to the minimum needed to hold the latch, an hour to get the door off and the rest of the bar unbolted and removed, and another half hour to get the door back on. The first door lined up first try, but the second took several tries to get it to fit right.
Old Jan 6, 2005 | 03:40 PM
mike c.'s Avatar
why remove the door bars?? is this on street or drag cars only? if it's street and you get hit in the door could that cause you to get hurt worse? i'm all for loosing weight so if it's safe for street cars i may do it too.
Old Jan 6, 2005 | 03:45 PM
critter's Avatar
Cuz I have a 6 point cage that has door bars stronger than what are in the doors, so the ones in the doors are redundant.
Old Jan 6, 2005 | 04:17 PM
mike c.'s Avatar
so,it seems this mod is for a race car and not really for a street car.
Old Jan 6, 2005 | 04:47 PM
critter's Avatar
Some guys remove them on street cars, but others think they are nuts for giving up the safety. My car sees street duty, but it has the roll bar, so I pulled the door bars.
Old Jan 7, 2005 | 01:08 AM
mike c.'s Avatar
i get it. alot of you guys take them out due to having a roll cage.i have no cage and a 10sec street car. i don't plain on adding a cage.the track has never said anything to me other then i should think about getting a window net.a net is funny since i have no cage.this summer i'm going to make a big dent tword the 9's and will still have no cage. thanks.
Old Jan 7, 2005 | 07:54 AM
critter's Avatar
LOL!! Now that is funny!!
Well, I acutally would not have put a cage in my car at the time, but when I hit 11.98 I got sent home. Since I am aiming for the bottom 10s, I am glad that I have it. S**t happens. I've seen a couple guys get upside down at the local track. Looking for traction last fall, we went too low on tire pressure and I had my hands full keeping the car in my lane. I could have lost it easily, so I don't regret the cage.
Old Jan 7, 2005 | 12:11 PM
NLang's Avatar
mike c., though I'm sure most here inderstand where you're coming from (street car), 9 seconds is a little quick to be avoiding rollover equip. You only get one body...
Old Jan 8, 2005 | 02:20 PM
mike c.'s Avatar
NOSEUP-i have been in a rollover wreck two years ago. i had the side of my head stapled back togeather. it's no different then a guy taking his new ride on a top out run to see what it will do,cars don't come with cages. i'm sure most all of us have seen our 150mph speedo and toped it out(i have) my car looks stock,i just want to keep it that way for as long as i can.
Old Jan 8, 2005 | 07:53 PM
NLang's Avatar
Miss that part? There's no need to explain as your "street car" reasoning goes w/o saying. Last yr, when a slick blew hammering 4th 3/4 down the track, my heavy hunk of ugly bars kept my face from painting the concrete divider. I don't see how you could avoid it after having your head stapled. I don't know anyone that likes seeing bars everwhere, but apprearance over life? Just a tad ridiculous, no? I guess not everyone has a family to live for or support...
Old Jan 9, 2005 | 05:31 PM
Nova5's Avatar
ya know the only problem with removing them? some ******* that comes in from the side is gonna **** you up. mine were in, are in, and staying so.
http://photobucket.com/albums/v230/nova5/z28damage/
view pass is "scfyb"
Old Jan 9, 2005 | 10:31 PM
  #32
Magnus's Avatar
LS1TECH Sponsor
Just cut a hole in the very bottom of the door so you can slide the bar out on an angle. You'll never see the hole. You have to take the door off to slide it out through the wiring harness hole.
Old Jan 13, 2005 | 08:51 PM
  #33
mike c.'s Avatar
noseup-death comes to us all my friend,sooner,later or how makes no difference to me. if i die,my family will not need me or anyone to support them for they will get tons of cash from my death
Old Jan 14, 2005 | 02:17 PM
  #34
12secondv6's Avatar
Hey Keith, you wouldn't have any pic's of the underneath of your doors would you?
Thanks!
Old Jan 14, 2005 | 08:31 PM
  #35
Magnus's Avatar
LS1TECH Sponsor
I don't have pics... but the fiberglass cuts REAL cleanly with a hole saw cutter... and then after you lside the bar out you just put some black paint on it.. and you can't even see it.. unless you are on the ground looking up.
Old Jan 17, 2005 | 11:48 AM
  #36
Camaro_Zach's Avatar
well this is a problem for me, because i often show people the bottoms of my doors. people always say their bmw door bottoms are better than my camaro door bottoms and i like showing them whats up. so i guess i cant do it this way.
Old Jan 28, 2005 | 09:42 PM
  #37
MRI-TEK's Avatar
This was a real P.I.T.A for me !!! Took me 2 weeks for one door !! Well pretty much every chance I could get I would get in the garage and mess with it , Thats why it took 2 weeks for one door. This is definetily not worth it unless you plan to go with lexan windows IMO.
Old Feb 21, 2005 | 04:53 PM
  #38
MR NASTY's Avatar
You damn Skippy!
Old Feb 21, 2005 | 06:30 PM
  #39
Torkman15's Avatar
10 Second Moderator
Originally Posted by Larry
I ground a 10 mm socket with flats on the end so I could wrench it with an open end wrench. Worked like a charm!
I did the same exact thing yesterday, no cutting and no holes cept for the door wiring hole. Take the door off and take the bar out through the wiring hole. Takes a little more time but looks supersano!
Old Jun 6, 2005 | 01:20 PM
  #40
Cal's Avatar
Cal
Well I might as well add my technique since it's different than any listed:
Cut down a 10 mm socket on a lathe and MIG welded some flat steel to it for a handle. Once broke loose, I cut a slot in the end of the bolt with a Dremel and quickly turned it out with a long screwdriver.
Cut the door bar up in four pieces with an acetylene torch, using an exhaust shield to protect the door.
Each bar is 7.1 lbs on my digital fish scale; the inner door pannel is 9.2 lbs. The only part I put back on was the small plastic bezel that goes around the door handle and the switches.
