Drag Racing Tech
Needing help on how to wire Harlan 2 step
Old Dec 5, 2004 | 01:11 AM
Street Racer's Avatar
Default Needing help on how to wire Harlan 2 step
As the topic states I need HELP!!! I was wondering if I could get a little help on how to wire up a Harlan 2 step. I bought the unit used and I have no wiring diagram .....
thanks,
Mike H.
Old Dec 5, 2004 | 01:30 AM
z-ya's Avatar
I think he has instructions posted up on his site.
Old Dec 5, 2004 | 09:46 AM
y2khawk's Avatar
Mike
The instructions should be in your mailbox.
Old Dec 5, 2004 | 10:55 AM
Steve Burger's Avatar
LS1TECH Sponsor
What do you need help with? Also Harlan, did you ever figure out what PCM wire I can use to activate the 2 step?
Old Dec 5, 2004 | 11:48 AM
y2khawk's Avatar
Steve
It's the blue connector, pin 32. Should be a gray wire. That's the clutch input for the 99+ PCM's. Tap directly to that wire with the gray wire from the 2 step.
Old Dec 5, 2004 | 04:33 PM
LS1TECH Sponsor
Thanks
