4L60E 1/8th shift points.
Thanks
Alan
I race full length, but mine would shift shortly after the 60', maybe 100' or so, then if i recall into 3rd around the 1/8th. Cant say for sure, its been a year. But tuning the trans helped out greatly.
Good luck
Charlie
Derek
the car is shifting just before the last two cones into 3rd in the 8th mile.
7.51@91.xx MPH
3.23 gears
The car has been retuned and the shift points and pressure have been checked. I am going to the track tonight for some test runs with the video camera mounted and scanner hooked up. Have been told it might be a cracked drum with a pressure bleed because the pressures on the first tune were set through the roof.
Alan
