Drag Racing Tech
Drag Wheel Weights
Old Jan 18, 2005 | 08:18 AM
Bhogan909's Avatar
Default Drag Wheel Weights
Does anyone know the differences in weights between Draglites, Pro Stars, and Warriors? Which wheels are the lightest and which would be the heaviest?
Thanks in advance
Old Jan 18, 2005 | 09:54 AM
GeorgeC's Avatar
I think you're splitting hairs between those three choices. There won't be enough difference to notice. Go with what you think looks best.
Old Jan 18, 2005 | 09:59 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've posted the weight of Weld wheels before, but it was over a year ago. Draglites were lighter than Pro Stars, but only by a 1 lb or less than a full lb. I think that we were saying like 14 vs 15 lbs. If you call 1.800.788.weld the folks there will give you the box weight of the rims.
Old Jan 18, 2005 | 11:20 AM
GeorgeC's Avatar
The XP series of the Weld's are much heavier than the "traditional" ones... (Just in case you're looking at the XP wheels)
Old Jan 18, 2005 | 04:35 PM
next's Avatar
When I talked to Weld, the Draglights and ProStars were quoted as being the same weight. Actual weight on them might show a slight difference like PSJ said.
My XPs were close to 5 lbs heavier per rim as they are alloy and not forged aluminum.
