Drag Racing Tech
What Torque are you using to install your race wheels?
Old Jan 21, 2005 | 07:45 AM
SlickVert's Avatar
Default What Torque are you using to install your race wheels?
I have a set of Bogarts and what TQ do you all use?
Old Jan 21, 2005 | 12:25 PM
DietCoke's Avatar
80 ft/lbs
Old Jan 21, 2005 | 12:45 PM
Steve Burger's Avatar
LS1TECH Sponsor
75 for my welds.
Old Jan 21, 2005 | 12:46 PM
MeanWS6's Avatar
Originally Posted by DietCoke
80 ft/lbs
Is that on all fours, or are their different TQ values for fronts/rears
Old Jan 21, 2005 | 12:49 PM
SilverGhost's Avatar
Motorboater
i don't use a tq wrench, just crank em on
Old Jan 21, 2005 | 01:18 PM
JS's Avatar
JS
Use a tq wrench,it loads the wheel correctly...
60 pass/70 pass/80 pass DONE
Old Jan 21, 2005 | 06:44 PM
Nate_Taufer's Avatar
most use 75-80 lbs or torque. that's pretty much industry standard.
Old Jan 21, 2005 | 06:50 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
100 lbs.
Old Jan 21, 2005 | 08:46 PM
Motorboater
guess i've never heard really what, if any, bad things can happen by not using a TQ wrench?
me and everyone i race with has never used a tq wrench to put any wheels, drag or otherwise on our cars. i'd start using mine if i had a good reason, car to share some info??
Old Jan 22, 2005 | 09:27 PM
2001-WS6's Avatar
If you are not using spacers... probably nothing bad is going to happen if you're in that 75-80lbs range for Weld and Centerline on big studs. Minimum two stage tightening is a good thing for peace of mind though.
I've seen guys using spacers that overtorqued and cut the studs on sticky tracks after a few passes. It looks funny on the video but not much fun in the hot seat when you loose a rear while on the launch.
Is that 100lbs on just the firebird or both cars bickelfirebird?
Rick
Rick
Old Jan 22, 2005 | 09:37 PM
11 & 7 Second Clubs
100 lbs on the Firebird's rear Weld wheels and the lugs have spacers. The amount of torque for any given car's lugs/wheels is determined much the same way the torque for, say, main cap studs would be determiend, e.g., by the material and diameter of the stud. Our Firebird has 5/8" studs which require 100-110 lbs torque versus the smaller 7/16" stock F-body studs, which require 75 to 85 lbs.
Old Jan 22, 2005 | 10:26 PM
JS's Avatar
JS
I make a 3 pass tq sequence up to 80lbs with my spacers and have NEVER had one problem,Knock wood....I run 1/2 studs all around but this winter I'm going to grind the calipers alittle more and do away with the spacers....
Old Jan 23, 2005 | 03:04 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I go 90 ft lbs with my welds.
Old Jan 23, 2005 | 04:36 PM
Hardtop00SS's Avatar
if you don't torque the wheels for every day driving, you can warp the rotors.....
Old Jan 24, 2005 | 12:02 PM
STL2SLO's Avatar
I torque my Welds to 90 with no spacers on front and rear.
Old Jan 24, 2005 | 04:41 PM
1madss's Avatar
80 ft/lbs on Pro stars. I check them after every couple of runs because they will loosen up after a bit. Plus it give me something to do while waiting in line
Old Jan 24, 2005 | 07:43 PM
WickEdSix98's Avatar
90 ft/lbs here. I believe the instructions that come with Weld wheels calls for 75-85 ft/lbs. with 1/2" studs.
Old Jan 24, 2005 | 07:52 PM
11 & 7 Second Clubs
The stock 7/16" studs should not be torqued past 85 lbs. IMHO.
