Drag Racing Tech
Another Cage Question
Old Jan 21, 2005 | 11:07 AM
ApacheDrill's Avatar
Default Another Cage Question
I appologize for making another post, but i am gathering as much info before making any mistakes with my cage install and choices..
What is Jig notched?
Is there a differnce between bolt in a weld in other then the fact that you can remove a bolt in?
How much weight is saved with Cromoley over mild steel?
Thanks In Advance..
Old Jan 21, 2005 | 11:30 AM
MADMAN's Avatar
LS1Tech Sponsor
Jig notched is fish mouthing the tube so it will fit around its mate.
Mild steel weighs 2.75 lbs per foot. Chromemoly is 1.1 a ft.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jan 21, 2005 | 11:43 AM
What are the benifits of Jig Notching?
Old Jan 21, 2005 | 11:56 AM
smokinHawk's Avatar
easier to install and weld, its hard to weld the tubes together if there is a big gap
Old Jan 21, 2005 | 12:48 PM
GeorgeC's Avatar
The Wolfe jig notching is done precisely enough that the bar is literally a hold and weld installation. With most rollbar kits, you still have to do a bit of trimming/final fitting to the car. With a jig-notched Wolfe, you don't.
Old Jan 21, 2005 | 12:52 PM
SilverGhost's Avatar
Motorboater
my jig notched wolfe went in easy as cake
Old Jan 21, 2005 | 01:24 PM
Sounds great..I appreciate it..
