Drag Racing Tech
vac pump.
Old Feb 13, 2005 | 05:18 PM
blubird's Avatar
Default vac pump.
Who has ran a vacuum pump and how did you get the drive kit to work. Any pictures would be extremely beneficial.
Old Feb 13, 2005 | 08:52 PM
speedracerz's Avatar
i too am wondering this.
Old Feb 14, 2005 | 10:34 PM
Stu'sWS6's Avatar
You need to fabricate a bracket to mount the pump-most put it either where the a/c or ps pump was. Next you need a flange that bolts to the balancer, and a pulley bolted to the flange. Mine is a v-belt setup.
Hope these help...The bracket bolts where the a/c compressor used to be.
You will also need a breather tank and vacuum relief valve in your valve cover. Good luck.
Attached Thumbnails vac pump.-vacpump1.jpg   vac pump.-vacpump2.jpg   vac pump.-vacpump3.jpg
