Drag Racing Tech
How strong would this be?
Old Mar 1, 2005 | 05:49 PM
SPANKY LS1's Avatar
Default How strong would this be?
Instead of a BMR Extreme, Wolfe, or Madman torque arm....
Use one of the below crossmembers with a standard adjustable bolt in torque arm. Wouldn't it be basically the same thing as one of the above mentioned chassis mount torque arms? It would free up a TON of room for dual exhaust, and should be nearly as strong, right? How strong do you think this setup would be compared to the above?
Old Mar 1, 2005 | 10:54 PM
glennster's Avatar
I've rode in one BMR extreme installed camaro and the noise was way to much for me.I have the BMR crossmember coming in tomorrow w/bushing.I think its a great idea.
Old Mar 2, 2005 | 02:24 AM
SMOKIN01TA's Avatar
ditto with glennster, im still runing mine on the trans and the new design was a great idea, definalty better than the extreme setup due to the fact that is putting pressure further up front.
Old Mar 2, 2005 | 01:48 PM
1fastWS6's Avatar
Its just as strong as the other setups out there. Plus you can change the instant center location a little with the BMR bracket which is a plus. I started making a bracket just like the black one above 2 years ago when I built my torque arm. Just never finished it up. It's a great idea.
Old Mar 2, 2005 | 03:00 PM
GIZMO's Avatar
I have had a set-up like the black one in my Firebird for years. It works pretty well. I use an Edelbrock torque arm that I beefed up. Sixty foot times in the low 1.4's.
Daren
