Drag Racing Tech
Lightweight car... easier to hook up or harder?
Old Jan 12, 2003 | 07:59 PM
quickWS6's Avatar
Default Lightweight car....easier to hook up or harder?
Less weight is as good as more power (assuming you can get it near the common 100 lbs= 10 hp). So, if you have less weight, does that also mean that the car is harder to hook up? I realize that where the weight is taken from effects this. Weight off the front=easier to hook up since it has more weight transfer....weight off rear=harder to hook up because there is less weight over the rear tires. But, if you removed it from the middle or equally from the front and back, what would be the effect?
Old Jan 12, 2003 | 10:20 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Lightweight car....easier to hook up or harder?
If you were not allowed to do any suspension changes or tuning once you removed the weight, then removing that weight would make it harder to hook. But, luckily, we can tune/adjust the suspensions in lightweight cars and change the tire sizes to accommodate any drops in weight.
If nothing else changes but weight, then yes that makes the car harder to hook.
-Tony
Old Jan 12, 2003 | 10:43 PM
quickWS6's Avatar
Thanks for clearing that up for me Tony
Old Jan 13, 2003 | 01:17 AM
TanRchy's Avatar
yea, its true. i dropped 130lbs off my car for 1 week. It was much harder to hook at the track. I gained 2 mph buti lost like .3-.6 in e.t. Not worth it, until i get some ET Streets.
