Line lock questions
Sorry but I cant simply hop out and test mine, nor have I ever had the desire to try it, but if in fact it works thats good info to know. "you're my boy blue!"
if so here are some tips
I am guessing you may want to do this so that you can use the line lock to hold the rear wheels during a lauch.
There are a few problems with doing it that way:
-most classes for non delay races only allow line locks on non-drive wheels only.
-a lot of classes for non delay box races(footbrake) don't allow launching with a line lock and/or a button.
-after you launch you may forget to turn it off and most line locks recommend that you only have them on for a max of 60 sec. doing so my damage the line lock.
-unless you turn the line lock off before the end of the track you will not have rear brakes at the end of the run.
-if you forget to turn the line lock off you will not have rear brakes when you leave the track.
http://www.one4thmile.com/camaro-fir...2/braking.html
