Drag Racing Tech
Suspension Help
Old Mar 9, 2005 | 07:18 PM
oOoLy's Avatar
Default Suspension Help
I have now ( BMR Subframe connectors, BMR K-member, BMR Torque Arm, BMR Lower Front A-Arms, BMR Rear Adjustable lower control arms, Relocation Brackets, BMR Adjustable Panhard Bar, Front/Rear Hal Shocks, Sway bar, Eibach front/rear springs and Drive Shaft Safety Loop ) so i want to know what else i need for drag racing ?
Thanks
Adnan
Old Mar 9, 2005 | 07:48 PM
Little G's Avatar
Do you feel you need more hook at this point? How have your times been affected by your current suspension set up? The only things left that you could do is to switch to the short torque arm and get a drag rear sway bar. Also, you could ditch the front sway bar when you race. I haven't had a front sway bar for months.
Old Mar 9, 2005 | 08:27 PM
oOoLy's Avatar
I did not Install the parts yet and how about the Heavy-Duty Anti-roll Bar ?
Old Mar 9, 2005 | 08:42 PM
Little G's Avatar
The anti-roll bar is a good mod if you're making enough power to twist the chassis off the line. Personally, I'm not making near enough power to justify it, so I just have a stock sway bar.
Old Mar 10, 2005 | 06:17 AM
oOoLy's Avatar
When i use the anti-roll bar should i removed the sway bar or i must but it with the sway bar ?
Old Mar 10, 2005 | 07:22 AM
Little G's Avatar
No, it replaces the sway bar.
Old Mar 10, 2005 | 10:00 AM
mongse's Avatar
I ruin the end of films...
I'd install what you have and make sure it's setup correctly before throwing more at it.
Old Mar 10, 2005 | 06:31 PM
oOoLy's Avatar
which one is better the anti roll bar or sway bar for drag racing ?
Old Mar 10, 2005 | 07:11 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Anti-roll bar is better for drag racing hands down. If it's a street driven car be sure to go with a poly bushing end link set-up because there is a significant noise effect with the adjustable extreme anti-roll bars. I would install what you have, remove the front sway bar and adjst the shocks for ideal transfer and see how the body twist is. The adjustable shocks can help balance the car as well. Then decide how much rear anti-roll bar you need. Depending on your power level , you may find that a lesser aggressive rear bar isn't needed.
FWIW- you have a great start already for a nice drag set-up. Good luck!
Old Mar 10, 2005 | 07:23 PM
xxx's Avatar
xxx
If you wanna race.... throw/give away that BMR tq arm and call MADMAN
....other than that is looks pretty good
Old Mar 10, 2005 | 07:25 PM
PRAY HRD's Avatar
ok, i thought i responded to this earlier......odd.
anyway, earlier i said that if you were looking to get a better bite/60', i would look into different springs. i'm not familiar with the spring rate of the Eibach's, but i wouldn't think that they're ideal for drag racing. if i'm wrong, someone correct me. do the anti-roll bar if you're planning on going faster than mid 10's, and remove the front sway bar if you haven't already. and yes, the Madman t/a is GREAT, but the BMR X-treme unit has some fast cars using them with great results too. they do make a pretty decent piece. if you're looking to go low 9's or faster, then i would definately say there is something to be had with Madman's t/a. that's just my oppinion, and xxx can prove me wrong if possible. i have a BMR X model, and was planning on using it, but recent results of Madman's t/a has made me reconsider because i do plan on going 8's by next year and i don't want to change it later.
Dave
Old Mar 10, 2005 | 08:07 PM
xxx's Avatar
xxx
I have nothing against the other tq arms.. I just seen first hand what Madman builds his out of, and if it's staying together under our cars @ 3500 pounds and 1200-1500 hp its pretty tough.
Old Mar 10, 2005 | 08:19 PM
PRAY HRD's Avatar
ok, now i see............no offense dude, but i hate when people have the exact same post in 2 different sections. that's why i had thought i replied to this already.
https://ls1tech.com/forums/suspension-brakes/287718-suspension-help.html
