Drag Racing Tech
Tire size question
Old Mar 16, 2005 | 01:17 PM
waltsfastz's Avatar
Default Tire size question
I did a search and dint find exactly what I was looking for thought it has been asked ten thousand times. I have some 15X4 weld prostars and I am looking for the size tire I need that will keep close to the stock ride height, I found 165/15 but waht is the other number?What is everyone running? Thanks
Old Mar 16, 2005 | 05:22 PM
Little G's Avatar
There is no other number. It's 165R15. Not sure why there is no aspect ratio but that's the size I run. When you go to the tire place just ask for Volkswagon tires to use for skinnies, they should know what you're talking about.
Old Mar 16, 2005 | 05:58 PM
Squintz Palladoris's Avatar
M/T 26x7.50x15 8ply
Brad
Attached Thumbnails Tire size question-dyno2.jpg   Tire size question-anotherbrad.jpg
Old Mar 16, 2005 | 09:43 PM
waltsfastz's Avatar
Ok, Thanks fellas
Old Mar 16, 2005 | 09:53 PM
CAT3's Avatar
Restricted User
the 165/15's are metrics radials and the others are Bias-Ply. I ran the 26x7.5x15s with regular Radials and DR in rear on street never had any issues, just have to be particular on the air pressure.
