Drag Racing Tech
Cage thru the dash pics?
Old Mar 17, 2005 | 09:51 AM
WhtLT1's Avatar
Default Cage thru the dash pics?
I've always wondered wat it looks like going thru the dash and wat is needed. How does everyone do it? just cut a hole and drop the bar thru? Or do most of you kinda notch the dash so you put the bar in first and then the dash around it?
Old Mar 17, 2005 | 11:11 AM
Outlaw's Avatar
I notched the dash to fit around the cage.. that way I can always remove the dash if needed.
Old Mar 17, 2005 | 09:30 PM
Torkman15's Avatar
10 Second Moderator
Yup same here. The dash will be alot happier if you notch it. You will too when you need to mess with wiring and crap behind the dash at a later date.
