Drag Racing Tech
Lightweight steering column
Old Sep 26, 2010 | 10:06 AM
InsaneAuto86's Avatar
^^ what are you guys using for turn signals? Just dash mounted switches? I'd like to weld a tab onto the column and mount a stalk that has headlights, hi-beam, and turn signals.
Old Sep 26, 2010 | 11:08 AM
jcoosi's Avatar
I am using this http://www.speedwaymotors.com/Hi-Tec...dard,2366.html with two momentary switches that you can pick up at radio shack.
Old Sep 26, 2010 | 02:26 PM
DMH Fabrication's Avatar
We have two of them in stock if anyone needs one
Old Sep 27, 2010 | 09:17 AM
Why exactly is that necessary?
Old Sep 27, 2010 | 11:09 AM
Steve Burger's Avatar
LS1TECH Sponsor
We will have one made of billet aluminum and polished in the near future.
Old Sep 27, 2010 | 11:21 AM
jcoosi's Avatar
I am not using a multi function switch so that is used to control the turn/hazard signals
Old Sep 27, 2010 | 02:49 PM
The Guy in MY 99TA's Avatar
steve... what about the possibilty of one that uses a factory style headlight, wiper, and blinker switch???
that would probably just about defeat the purpose of having a lightweight column... but I'm trying to get rid of every bit of weight I can and still keep the car functional.
Old Sep 27, 2010 | 10:31 PM
If I can figure this out I will def order a column. Even if it wasnt a factory style stalk, it still needs to be functional and look good. There has to be a stalk from a Honda or Dodge, or something that will work and someone could make an aesthetically pleasing mount for.
Old Sep 27, 2010 | 10:40 PM
94Z28rag's Avatar
That's what I'm doing. To the left by the headlight/dimmer switches.
Old Sep 28, 2010 | 03:55 AM
MUCH easier and more practical to rewire a new switch. There is no good way to make the factory one work on the column or we would have done it already.
Old Sep 28, 2010 | 07:07 AM
What are the options for windshield wiper control? High beam control? Is it possible to install an engine start button that will start and shut off the engine, completely bypassing the keyed ignition?
Old Sep 28, 2010 | 07:59 AM
  #32
LS1TECH Sponsor
We can look into a turn signal option. I doubt we would work on a setup that retains all of the functionality on the current column. It defeats the purpose of a lightweight one and the one we design will not be NTSB compliant.
I would consider this a track part and not soo much a street part.
Old Oct 15, 2010 | 11:56 PM
  #33
fash00's Avatar
Anyone realize the thread was started 5 years ago?
Old Oct 17, 2010 | 10:18 AM
  #34
jcoosi's Avatar
You can wire in an old school floor mounted dimmer switch to control the hi/low beams.
