Drag Racing Tech
New Best and a Question
Old Apr 12, 2005 | 10:45 PM
Josh@PremierAutosports's Avatar
Default New Best and a Question
Weather was great here in memphis and the da was 1050 a little earlier in the day. I made 6 passes with 4 of them being about the same
60- 1.52-1.58
1/8-6.71-6.78
mph-101-102
1/4- 10.50-10.60
mph- 127.9-128.8
My last 2 runs were different. The second to last I lined up behind a drag car and I got in his rubber. The car hooked great and this is the first pass the car has felt fast. We didn't change any tuning or nitrous jets but picked up 4mph. The temp might have dropped slightly but this run was 12 min after the previous run.
60- 1.469
1/8-6.621
mph-103.10
1/4-10.436
mph-132.18
The last run I hot lapped it again and the bottle pressure was up from the normal 1050-1075 to 1125.
60- 1.547
1/8-6.714
mph-105.85
1/4-10.556
mph-127.49
So the second to last run I picked up 4 mph in the 1/4 but next to nothing in the 1/8. The last run I picked up 2-3 mph in the 1/8 but lost it all up top. All I can think is the computer is pulling timing on most passes but didn't on the 2nd to last run and pulled timing on the big end of the last pass. I have yet to retune the car and its running 28 degrees timing, 11:3 compression, pump gas, and 150 shot. Does anyone have another guess at why I can normally bracket race the car then all of a sudden pick up 4mph without changing anything. My shift points were always within 200rpms on each pass.
Old Apr 13, 2005 | 01:11 PM
Any ideas?
Old Apr 13, 2005 | 08:39 PM
B18B1LS1's Avatar
Have you checked the plugs? I have burnt plugs just enough to drop my times off a bit but nothing too major. Just a thought.
Old Apr 14, 2005 | 09:48 AM
The plugs were new and still look great. The car never slowed down it just made 1 pass 4mph faster than the rest.
Old Apr 14, 2005 | 10:57 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
It just happens every once in awhile. Things should be fine the next time out.
Coach
Old Apr 17, 2005 | 04:12 PM
tboysen00's Avatar
nice times
