Parts list needed
I need to know what headers will work.
What kind of K-member will adapt to the small block motor mounts.
What sort of clearance problems for the alternator if I run it directly off the crank, and have a bracket fabbed up for it.
I already have a sheetmetal fuel tank, and fuel system on order. The only real problem I forsee is the above listed parts. I know Madman and a few others on here are running regular small blocks. Obviously you can see from my sig below that I already have every drag part the car needs for single digits, including a TH400 with a transbrake. I'm just tired of chasing demons in the tuning, and when that wasn't enough to **** me off, a perfectly good motor let go due to GM not being able to build a descent freaking oil pump.
Thanks in advance for any and all input!
