Drag Racing Tech
12 Bolt question
Old Apr 25, 2005 | 10:59 PM
RedHatRdRacer's Avatar
Default 12 Bolt question
Well I have a 12 bolt in my car made by moser, as i was swapping my rims back over i noticed all my studs are bent on both sides. Does moser warentee this or what should i do
Bryan
Old Apr 26, 2005 | 09:01 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
You will need to replace them yourself. We put 5/8 wheel studs on our 12 bolt.
Coach
Old Apr 26, 2005 | 07:20 PM
This happen alot?
Old Apr 26, 2005 | 07:48 PM
SilverGhost's Avatar
Motorboater
can happen for several reasons..usually the lugs not being torqued correctly(usually loose)
I check tightness on my rear lugs after every 2 passes while at the track because of the tendency for drag wheels lugs to loosen up a bit, i have never broken or bent any studs as of yet.
swapping studs is pretty easy and new ARP ones are cheap..like 13 bucks an axle or so from Speed Inc.
