Drag Racing Tech
Do I need more gear for the track?
Old May 4, 2005 | 09:17 AM
68maro's Avatar
7 Second Club / STF Veteran
here then factor in slippage
http://www.tciauto.com/tech_info/calculators.htm
Old May 4, 2005 | 10:38 AM
PewterZ28's Avatar
SUX2BU, you should make it. I currently have 26" tires and 4.10 gears and a YTP 4400 and I am trapping 120 mph at 6600 RPM.
Bain, using 5% converter slippage, you will cross the traps at 6957 RPM at 125 mph w/ 4.10's and 26" tires. That's cutting it close but it should work. Actual converter slippage should be between 3~6%. I still think you should go with 4.10's and 27" tires or 4.30's and 28" tires.
Go here http://www.tciauto.com/tech_info/calculators.htm#5 and scroll down to 1/4 Mile RPM calculator.
