Drag Racing Tech
Why does my car trap so low?
Old May 13, 2005 | 01:19 PM
josh99ta's Avatar
Sold The Fun Stuff :(
Default Why does my car trap so low?
Granted it's an auto and at stock weight, but lets recap...
Stock the car went 13.8 @ 101 I believe.
Lid + cutout and better weather and traction got me 13.2 @ 105.
Now I've added a converter (3200 stall) and 17x9 wheels w/ 275 tires (over the stock 16x8 w/ 245 tires).
Car now usually traps 103 in the 1/4 mile.
Previous best in the 1/8th with lid and cutout was 8.5 @ 84. I've only ran the 1/8th since the gears went in, but now the best with the converter and BFG drags out back along with 3.42 gears over my stock 2.73s, on stock 16x8 wheels is 8.3 @ 83, but I was running 82 most of the day.
Just curious, will the stall slipping as well as the extra weight of the 17x9 wheels and larger tires really hurt my trap speeds that much? Even for an auto car it just seems like my car is trapping very low. There are other auto cars out there with full bolt ons, barely any weight reduction, and a big cam running 120+. Granted weight reduction might be worth a few tenths and a few MPH, but even if my car had the full bolt ons, I doubt I'd see much more than 110 in the 1/4, and even with a huge cam probably only 115 or so.
Would a bigger (4400) converter, more gear like a 3.73, little things like the short belt and the like, and weight reduction really get me up close to 120 if I had a nice sized cam to go with it all? Right now I'm planning on a small cam with ported heads. Is there any reason that the small cam with ported heads, more gear (3.73), and more stall (4400) couldn't trap close to 120 MPH?
Old May 13, 2005 | 01:26 PM
Little G's Avatar
I would attribute it to the tires. Rolling resistance combined with rotational mass will slow you down big time.
Old May 13, 2005 | 01:52 PM
WJ SOM SS's Avatar
Josh, you never said if you have 2.73's or 3.23's? I trap from high 107's to low 109's w/Vig 3200, 3.23's, a 26" tall tire and stock motor and exhaust manifolds, depending on the weather.... WJ
Old May 13, 2005 | 02:23 PM
John_D.'s Avatar
I have some weight reduction (k-member, lightweight battery, no a/c) with heads/cam/headers/ls6 intake and a 3000 rpm stall, running 113mph in the 1/4. That's at Beech Bend which has a little more elevation than some of the other tracks you hear people quoting times from... Same gears as your new ones, 3.42. The LS1 will make up some time on the last half of the 1/4 too...
Old May 13, 2005 | 02:42 PM
Z00's Avatar
Z00
Josh, when I ran lid/exhaust/3000 stall I trapped 103/104 as well. 83 or so in the 1/8th. That was with 2.73 gears. Maybe it's just our tracks?
Old May 13, 2005 | 03:28 PM
josh99ta's Avatar
Old setup (105-106 traps in the 1/4, 84-85 in the 1/8):
Lid + cutout, 2.73 gears, Kumho 712 street tires 245/50/16
Race setup currently (no 1/4 traps, 82-83 in the 1/8):
Lid + catback, 3200/2.5, 3.42 gears, Kumho 712 275/40/17 in the front, BFG 255/50/16 rear
Without the 3.42s and on the BFGs the car was only trapping 103 in the 1/4. Haven't ran the 1/4 after the gears.
