Drag Racing Tech
60' techniques...
Old May 14, 2005 | 10:20 PM
CamTom12's Avatar
Default 60' techniques...
I need some suggestions...
I'm working with stock rear, Spec stg III clutch, and street tires. These tires are nice though in that they get really tacky with a good burn-out (I tested the theory today. They didn't get all slick like my old street tires did when they got too hot, instead they got all squealy and sticky .). I ran them at 22lbs pressure...
Today's best 60' was a 2.128. That was bogging at a ~3500 slip/dump. I have been slipping until the front starts to rise and then dumping the rest of the clutch. I tried a ~4k launch with a little bit faster slip/dump (but not a side-step) and that caught me some wheelspin and a 2.203 60'
I've heard of folks getting 1.9's and even 1.8's on street tires (not Nittos)...
Any tips? How did ya'll do it on stock tires, stock rear, M6?
Old May 14, 2005 | 11:26 PM
glennster's Avatar
Good luck,I never got sub 2.0's without nittos.Some guys say they can but I haven't seen it in person.
Old May 15, 2005 | 08:36 PM
WhiteSSP's Avatar
I did a 2.0 with crappy 245/50/16 Eagle HP's that are dry rotting and cracked. I did a 3-3200 rpm slip fairly quickly. Of course, I have a LT1 with a cam that moves my powerband around, so your results may vary. I think that with a good 275 tire on a 17" rim i could probably have hit a 1.9 60', but I'll be going to a 275 DR on a 15" rim shortly, so i wont be able to test my theory. And I think that slipping higher could have gotten me better results.
One thing I did find was that I was able to dump the clutch amidst slip much earlier than I thought. While you may think that if you dump early, you'll spin, i found that if you dump just early enough, you'll actually hook and be able to go WOT making your 60' that much quicker. I had just over 25 passes in my car last year, and got my 60's down from a 2.3 on my first time ever launching it, to a 2.0 consistantly (either a high 2.0 or a low low 2.1) all 10 passes last time at the track.
Old May 16, 2005 | 10:52 PM
rebersole2's Avatar
A simple solution to your problem, some M/T ET streets, a good burnout, stage the car, rev up to (insert your rpm here), dump the clutch and no more 60' what if's
Old May 16, 2005 | 11:59 PM
CamTom12's Avatar
a simple problem to your solution - stock rear...
I'm getting a 12-bolt this summer, I just want to learn how to launch delicately on street tires first while I have the chance to. I think being able to do that would make me a better racer all around.
Old May 19, 2005 | 02:52 PM
CharlieCobra03's Avatar
Hmm, the best 60' I ever go from street tires was a 1.98 in this car. Too much tq for 'em.
Old May 19, 2005 | 04:29 PM
BADSZ28's Avatar
I would like help on this too. Even with Nittos the best I could venture is 1.93 on a 4k dump dead hooking and vertually no clutch slip.
