Drag Racing Tech
Removing washer fluid pump
Old Jun 14, 2005 | 09:13 PM
blkZ28spt's Avatar
Default Removing washer fluid pump
I long since thew my washer fluid reservoir away, never used the thing to begin with since it sprayed over the entire car. In the quest to lose weight while keeping it comfortable (daily driver) I'd like to remove everything else I can that is part of the washer fluid system.
Where is the pump? I still get lost in these dang engine bays trying to follow wires around. Has anybody else removed it, where is it, what do you have to do?
Thanks.
Old Jun 15, 2005 | 07:31 AM
777's Avatar
777
I want the same, I haven't used it once since I got my car.
Old Jun 15, 2005 | 09:21 AM
DOUBT IT's Avatar
Me Three.
Old Jun 15, 2005 | 09:24 AM
Dustin's Avatar
?Isnt the pump the little black think on the resevoir. At least that is what it looked like when i took it out.
Old Jun 15, 2005 | 09:54 AM
GM Muscle's Avatar
Yeah, the pump is on the tank itself.
Old Jun 15, 2005 | 10:20 AM
blkZ28spt's Avatar
No kidding. Dang, and I thought I'd have a few more pounds to pull out.
Oh well, thanks for the info.
Old Jun 15, 2005 | 01:22 PM
jaberwaki's Avatar
you take out the bumper supports yet???
my cars both lost 70-80 lbs a piece losing those...
Old Jun 15, 2005 | 02:19 PM
777's Avatar
777
how to...? Side Effects?
Old Jun 15, 2005 | 03:48 PM
blkZ28spt's Avatar
No, I havn't. It just doesn't sit right with me to remove the bumper supports, as much as I'd LOVE to be able to remove that much weight. I have more or less stalled in my search of things to remove.
So far I've lost the spare tire/jack, AIR, EGR, front sway bar, rear seat with belts, washer fluid reservoir, insulation on underside of hood and all insulation from under the carpet (except under driver's seat). Car is my daily driver and only vehicle and must be driven in anything from -5* to 105* in heavy stop and go traffic and be relatively comfortable and totally safe for me and one other occupant.
Old Jun 15, 2005 | 04:05 PM
jaberwaki's Avatar
i get you ... let me put this to rest, those are not crash protection... your front bumper support is made out of styrofoam it might help (alittle) in a 5mph bump... but will to nothing in a wreck... the back bumper support is plastic.... it might be a little stronger... but not much....
long and short is, it aint saving your life...in a wreck
as for how to take it off...
all you have to do is undo all the pop rivits and 4-5 screws holding on the bumper cover, then unbolt the 4 bolts holding the support, then reattach the cover....
while your at it you can clean parts of your car you never get to see otherwize....(dirt weights too much)
Old Jun 15, 2005 | 04:07 PM
jaberwaki's Avatar
oh, and look at the heat sheilds on top of your muffler..... 5 lbs right there... and you'll never miss it...
Old Jun 15, 2005 | 04:45 PM
blkZ28spt's Avatar
Thanks jaberwaki, I will consider that. I'm heading to the track tonight to get some times (barring rain) and then again on friday for street car chaos. I'll look into the bumper supports for a last minute "mod" on friday since I have a short day of work. I removed all the heat shields I saw during my header swap, but didn't look as far back as the original muffler, if that is the area you are referring to.
Old Jun 15, 2005 | 04:49 PM
jaberwaki's Avatar
yup there is a big one back there too....
the front bumper support is easy enough to be a "right before the track" mod.... kinda like the passanger seat... take out the suport the night before... put it back when you get home from the track....
the seat you take out at the track(13 mm wrench and phillips head SD)
Old Jun 15, 2005 | 04:59 PM
blkZ28spt's Avatar
Good advice. I'm trying to run my car down the track exactly as I drive it day to day, which means what comes off stays off. I might swap tires, but that's it, and I can and sometimes do drive around with ET streets anyway.
Old Jun 15, 2005 | 05:03 PM
jaberwaki's Avatar
hehe... i do too.... i drive around on et drags most of the time.....(funny cops dont think its as cool as i do )
Old Jun 15, 2005 | 05:14 PM
blkZ28spt's Avatar
Yeah, I read about your ~50 mile commute in DC traffic (i think it was) on ET drags. psycho
j/k as long as it doesn't rain you're good.
