Recirculating Coolant Tank...?
Im in the same boat as you have a fuel cell there now so need the aftermarket tank.
maybe I need a bigger jug. what temp is your guys engine runnig at?? mines around 185, maybe that is higher causing more expansion
nothing great from the track. track prep and weather was crap last night. just ran NA, breaking in the new clutch and tranny. next friday will be SPRAY
hello 9's
OR
your radiator pressure cap is bad and is letting too much coolant by.
Check out this link
http://www.jazproducts.com/index2.htm
You have this kind
its just an overflow which fills up then spews out.
The kind I have and what you need is this one
its a recovery tank that fills up then syphons out as the coolant cools, it has a little syphon tube in it that does this and you hook up the overflow hose into the bottom fitting.
Sorry I did not catch that earlier I just got confused cause I had the petcock one the first go around and had it mixed up with my current one. In short you need a new tank
I still have the moroso in my tool box.
But hey, to each his own.
