Is it possible my suspension was bound up.....
Well, I just put my new badz lca's in the other day, and I kind of messed up and didn't realize that I had to put the washers on each side of the backside of the lca where it bolts to the relocation brackets to fill in the space, and just tightened it and the brackets smooshed in, but I was in a rush and said **** it, i'll fix it later.
So tonight I just got under there and took the bolts back out, banged the relocate brackets back out to where they should be and put the washers on each side and retightened the bolts and let the car down. I don't know what made me push on the rear, but I did and now all the sudden, the suspension is actually moving! So is it possible my suspension has been bound up somewhere all this time and that's been contributing to my hooking issues?
Yet now all the sudden everything seems to be moving and working perfect!!! I really hope that it was and now isn't, cuz maybe it'll start working now!!
The only other thing I can think of, I loosened and took the bolts out of the lca where it mounts to the relocate brackets and let that side drop with the car sitting on the ground (didn't even touch the front part where it bolts to the body), then I had to jack the rear up to take the tires off cuz I couldn't get at the brackets with the hammer cuz they were in the way. And then when I tightened the bolts back up, the rear was on the jack, didn't have the car on jackstands, so when I dropped the lca while the car was sitting on the ground, maybe I released any kind of bind that may have been in the suspension and then kept it out when I tightened it back up with the jack under the rear, but who knows!
Just my thoughts but you don't want to tighten anything suspension wise until the car is on the ground or binding can be a problem (as you described above). hope this ends up being a blessing for you hooking problems!
Derek
what LCAs did you have before?
From what you described here, you dropped the LCAs and all is fine now...
hmm....
Derek
PM me Brain's info as well, please.
PS - Madman's info wasn't about the shock settings, it was about how they mount, i'm sure he won't mind tellin you guys if ya give him a call, he doesn't seem to be the secrative type, always seems to wanna help others out with his knowledge, very nice guy!
