Drag Racing Tech
Having problems removing rear springs to remove isolators....
Old Aug 19, 2005 | 10:04 AM
Loudmouth LS1's Avatar
Default Having problems removing rear springs to remove isolators....
Everything i've read and everyone i've talked to says to disconnect the shocks, and then just let the rearend down and the springs will come right out, well I did that, and they're not coming out and I almost had the rearend sitting on the floor! Do I need a spring compressor or are they supposed to just come right out?
Old Aug 19, 2005 | 10:55 AM
Captain InsaneO's Avatar
Stock rearend? On my 9" rear its harder to remove the springs cause the center of where the spring sits is taller.
Old Aug 19, 2005 | 10:58 AM
SUX2BU's Avatar
disconnect the sway bar from the body. sometimes that holds it up too.
Old Aug 19, 2005 | 11:22 AM
Dragaholic's Avatar
9 Second Club NA
Whoops, I failed to mention that when I gave you directions. You'll only need to disconnect it where it connects through the bushings on the frame.
Old Aug 19, 2005 | 12:48 PM
Alrighty, guess i'll be doing this another day, hehe.
